DLLs not found
Hello, we have different robots using libraries that we made. We want to have all the libraries in a shared folder so all the robots have the last version if any update is made. The problem that we're having is that when we don't use the blueprism folder for the DLLs we get this error: Internal : Could not execute code stage because exception thrown by code stage: Could not load file or assembly 'RPA.Mailing.EWS, Version=1.5.6793.24497, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. Anyone knows how to solve this problem without using the BluePrism folder?
12 REPLIES 12
Hello Mikhail
did you ever solve this problem with the DLL?
(We are struggling with this aswell now in regards to the system Safran Project)
-Regards,
Ronny Falck-Olsen
Ronny Falck-Olsen
Hi All,
A quick note, putting the DLL into the BP install folder, usually solve the problem, just do not forget to restart the Blueprism application. DLLs are refreshed and load at application starting.
Robert Nemeth
developer
E.ON Ügyfélszolgálati Kft.
Europe/Budapest
Hi all,
I just had the same issue and I also had to restart Blue Prism to make it work (left the DLL in their original folder outside BP install folder, though).
Cheers Astrid
Cheers [FirstName]
