Data in excel sheet is not in English and header is making errors
SaraNof
I have Data in excel sheet are not in english, they have been shown as question marks
how to let this data be shown as readable form?
another issue that the header in the excel sheet is making this error, I believe it is the same issue above, about the language
Sara Nof
Dexter_Whelan_SAS
what are the headers of your excel sheet in question what do they actually say?
Dexter Whelan
Senior Developer/Mentor
SAS
Hi, Sara,
it is due to non unicode support in your excel VBO. Search the code stage for following string "Clipboard.GetDataObject().GetData(DataFormats.Text, True)" and change it to "Clipboard.GetDataObject().GetData(DataFormats.UnicodeText, True)" that should fix your issue.
Zdenek
Zdeněk Kabátek
Head of Professional Services
NEOOPS
http://www.neoops.com/
Europe/Prague
Hi Zdenek,
Where to search?
Sara Nof
Hi, Sara,
it depends on VBO you use. It may be in the action (Code stage) you call or in Initialise action/page. When you click on big rectangle to get to Business Object properties window and then you choose Global code tab you should find it there.
Zdenek
Zdeněk Kabátek
NEOOPS
Europe/Prague
