DataTable within a DataTable - Code Stage
Ed_PaulSantos
Hi, I am trying to use code stage to return a Collection that also has a collection inside and I'm having trouble with creating a DataTable that has a column with type DataTable. Any thoughts regarding the approach on this? Needing your expert advice. Thanks, Ed
FrankBaumann
Hi Ed, Here is some example code that you can use to add a nested datatable column 'Declare a new Datatable Dim dt As DataTable = New DataTable 'Add your Columns dt.Columns.Add(""ID"", GetType(Integer)) dt.Columns.Add(""Value"", GetType(DataTable)) 'Add a row dt.Rows.Add() 'Assign your output collection col_Out = dt
Ed_PaulSantos
Hi baumannf, This is great! Thanks! Ed
