Hi Yeswa,
When a deadlock occurs in SQL Server, two or more tasks are running simultaneously and holding locks on data. Then, each task requests to lock the data the other task is already holding. Both tasks wait for the other to give up, neither does. SQL Server could let this showdown continue indefinitely, but it won't. It picks one task – usually, whichever will be the least expensive to roll back – as the victim, and that task is killed.
To assist with raising this issue with support please could you speak to your Database Administration team and ask them to collect the deadlock information relating to this issue and provide this to support so they can investigate and help understand the issue. Collecting the deadlock information can be done by either enabling trace flags 1204 and 1222 or filtering the system_health Extended Events Session (Provided this is enabled) for "xml_deadlock_report".
Chris McGowan
Senior Technical Consultant
