Decrease Scheduler Running Speed
MaxBirkmann
Hi all,
the VMs our Robots are running on currently take very long to respond. When I run a Robot manually I dail down the speed to about 90% which is working fine.
I am wondering if it is also possible to adjust the speed also for scheduled sessions or if it can only be slowed down by adding wait stages and/or timeouts?
Kind regards,
Max
pdixon0
Hi Max
Any process running via Control Room / Scheduler will be ran at 'full speed'. The only way to limit this would be to add wait stages periodically, or use the timeout property of the Blue Prism stages, to throttle the running process accordingly.
Paul Dixon
Software Support Engineer
