Hi Marcelo,
You can try couple of things here:
- Firstly, ensure that first you activate the application window by selecting the Win32 element of your Application tree, then you send a Global Mouse Click on the spied element where you want to enter the text and at the end you use Global Send Keys Or Global Send Key Events on the
root application element(in my experience, many times people try to use Send Global Keys action directly on the element where you want to enter the text and that is the reason why it fails, remember it should always be the root node of your application tree).
- Secondly, you can provide some delay between each step to ensure proper working of the logic at runtime from Control Room.
You can refer the below screenshot for more details:
If still the above approach doesn't work, change the Element Type in your application modeller wizard for that specific element or spy with a different spying mode and repeat the above steps.
Do let us know if this resolves your query and wish you a Happy New Year! 😄
