Double Click option in AA or UIA Mode
_Amlansahoo
Level 11
HI Team,
Double click option is not available when we spy any element using AA or UIA mode.
Could you please tell some work around for that. I have tried various ways like sending global click center twice and all. But it never worked for me, especially in windows application.
Why Blue prism team is not enabling double click for AA or UIA instead of using work around?
Please help on this !
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
6 REPLIES 6
MadhurChopra
Hey Amlan,
Certain controls support certain action and not all actions are supported by all controls in all modes. This is largely owing to various limitations and considerations. I will highly recommend exploring the Application Manager Operations guide to see a detailed mapping of the actions and controls supported by each spying mode. You can access it by going to Help > View AMI Documentation from the Object Studio. It may also provide you insights into potential alternative approaches for what you are trying to accomplish.
I hope this helps.
Regards.
Madhur Chopra
Sr. Product Consultant
Blue Prism - Professional Services
America/Los_Angeles
Hi Madhur,
Thanks for your response. But I hope in future Blue Prism will include double click with AA and UIA mode.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
Get the UIA X and UIA Y attributes using Read stage
Use the navigate stage to send double mouse click action to browser window
Praveen Chinthaginjala
Senior Technical Architect
HCL Technologies
Europe/Amsterdam
faheemsd
Hi  Amlan,
Did you tried with Press button from the dropdown list?
Please try the press button
Syed Faheem
SYED FAHEEM
Project Engineer
Wipro Limited
Syed Faheem
RPA Tech Lead
Hi @praveencga I know the above method but it does nto work always. I have raised BP ticket for the same also.​
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
Hi Syed,
I have treied the same also. It works some time but for some situation it does nto work. So it will nice to have double click in those modes.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
