ERROR - MAPIEx - could not execute code stage because exception
NoePichot
Hello everyone,  I tried to dev a new method in MAPIEx VBO. This new method merge 'getMail' and 'ListMailsWithinDateTimes'. So i can list mails between two datetimes, and i can get informations about each mails, and not just IDs.  No error, but when i run it inside a process i got this : Internal : Could not execute code stage because exception trown by code stage: impossible to load the file or assembly 'BluePrismMAPIExAutomation, Version=2.0.6.0, Culture=neutral, PublickeyToken=null or one of its dependancies. The specific file is not found. PS : i got this error message in French, so i tried to translate it.   Noe
This is probably because the Mapiex dll file may not be installed correctly in Blue Prism folder. By default when you install MapiEx, it installs to C:\Program Files(X86)\Blue Prism Limited\Blue Prism Automate folder. Copy all the mapiex files from here and paste it to  C:\Program Files\Blue Prism Limited\Blue Prism Automate folder. This will work if its an 64 bit Blueprism installation.
