Edge Chromium - Error after second launching
29-04-21 03:48 PM
Dear All
I'm working to switch one of our Bots from IE to Edge Chromium (due to better performance). I setup everything, Edge is opening the first time w/o any problems and I'm able to perform the dedicated actions.
If I the Bot pick-up next Item, I got following message after a while after launching of Edge...:
Failed to launch application - The browser extension was not detected, please check that it has been installed and enabled. For more information, see the browser extension user guide. https://bpdocs.blueprism.com/bp-6-10/en-us/Guides/chrome-firefox/chrome-firefox.htm
Edge Version: 89.0.774.45
Blue Prism Version: 6.10
Extension: Blue Prism 6.10 Browser Extension V6.10
Have someone any Idea?
The browser extension is installed and also "Allow extensions from other stores" is Enabled.
Andre
Andre
29-04-21 04:42 PM
Thanks for your message; I not sure what is your version of Blue Prism or EDGE.
I see you share a link for BP6.10; for this reason, take a look at the current know issues in this version here: https://portal.blueprism.com/customer-support/support-center#/path/Upgrade-Expansion/Upgrade/1579866972/What-are-the-known-issues-in-Blue-Prism-Version-6-10.htm
Also, check you are using the correct version of EDGE for your version of Blue Prism; check the link here: https://bpdocs.blueprism.com/browser-compatibility.htm
