Error java - Panel designed with Java Swing interface
Genesis_LeykinW
Hi! I am trying to work with an application that shows some information of a table using a panel, when I try to read the table I get an error, please check the attached image for more information about the error. What can I do to read the information contained in the table? I have Java Access Bridge installed, and I have reached the developers and found out that the table is developed using Java Swing interface, or something similar Can you please provide any help? Thanks in advance
AndreyKudinov
Level 10
Panel is not a table. Your table is likely ON that panel - check actual element tree and fix your element attributes in modeller. You might also have some custom control, which is not supported by JAB.
