Excel sensitivity label
BeatrizSantos
Hello, I'm testing the Excel sensitivity label functionality, that requires to select a label before interacting with the workbook, and have not been able yet to figure out how to select a label automatically. Does anybody knows how to manage this using Excel VBO? Thanks in advance
Beatriz Santos
P2P Lead Europe
CHEP
Europe/Madrid
7 REPLIES 7
ewilson
@Beatriz Santos,
Sensitivity Labels are not currently supported in the ​VBO.
ManpreetKaur1
Level 8
Hi @Beatriz Santos,
Did you try code stage to achieve the functionality?​
Manpreet Kaur Manager
Manager
Deloitte
Hi All,
I have came across a requirement where I have to change the Excel file's Sensitivity label to Confidential before saving the file. Now I know the Excel VBA Code of it, however I was not able to make it workable via code stage. Can anyone help me on this?
Here is the VBA Code:
Sub SetSensitivityLabelConfidential()
  Dim myLabelInfo As Office.LabelInfo
  Dim Context As Variant
  Dim objWorkbook As Workbook
  Dim SConfidential As String
  Set objWorkbook = ActiveWorkbook
  Set myLabelInfo = objWorkbook.SensitivityLabel.CreateLabelInfo()
  Set Context = CreateObject("Scripting.Dictionary")
  With myLabelInfo
   .AssignmentMethod = MsoAssignmentMethod.PRIVILEGED     '1
   .ContentBits = 4
   .IsEnabled = True
   .Justification = "Write Your Reason"
   .LabelId = "Your Organization alpha numberic code for Confidential type"
   .LabelName = "Confidential"
   .SetDate = Now()
  End With
  objWorkbook.SensitivityLabel.SetLabel myLabelInfo, Context
End Sub
Thanks & Regards,
Pawan Panjwani
Pawan Panjwani
Hi Members,
Can any one help me with the above issue.
Thanks & Regards,
Pawan Panjwani
Pawan Panjwani
Did you find a solution? @PawanPanjwani1
Agustin Rodolfo Catalano
Computing Engineering
Santander Argentina
America/Argentina/Buenos_Aires
Yes Agustin, got the solution.
Pawan Panjwani
could you tell me how you did it? @PawanPanjwani1
Santander Argentina
