16-11-23 08:32 AM
I am facing an issue I never had before.
When I trigger a process manually by dragging and dropping a process to the resource, the process is executed without any issue just perfectly.
However, when I create a schedule and the schedule triggers the process on the resource OR even right click "Run Now" (does not make a difference) - the process does not run on the resource - we receive in the report the following entry:
When I drag and drop the Logout (or any other process) to the resource and run it - it works. I have no idea what could cause that.
Any idea ?
26-11-23 04:30 PM
Hello, have you tried restarting the application server?
20-11-23 01:16 AM
Hi Patrick Mueller,
The scheduler tested in the above scenario, how many tasks you have created. Did you put wait time after each task completion.
I would make sure the wait time is updated appropriately based on the windows login and log out time.
Harish Mogulluri
22-11-23 08:00 AM
@Harish Mogulluri So actually it is even more strange - so the machine is totally idle - nothing scheduling, nothing planned.
When I try to run a schedule manually for this machine (or even a planned schedule) I receive this message - always - when I drag and drop a process to the machine and start it from the control room without the scheduler...it works perfectly fine.
It only happens on this one machine and I do not know why.
26-11-23 04:30 PM
28-11-23 08:39 AM
@LeonardoSQueiroz Wow - that really solved the issues - we restarted the application server service overnight and now we are not receiving this time out issue with that one particular resource any more - thank you very much !
02-12-23 10:23 PM
