Exception when using the scheduler
PatrickMueller
I am facing an issue I never had before.
When I trigger a process manually by dragging and dropping a process to the resource, the process is executed without any issue just perfectly.
However, when I create a schedule and the schedule triggers the process on the resource OR even right click "Run Now" (does not make a difference) - the process does not run on the resource - we receive in the report the following entry:
When I drag and drop the Logout (or any other process) to the resource and run it - it works. I have no idea what could cause that.
Any idea ?
Best Answers
LeonardoSQueiroz
Level 10
Hello, have you tried restarting the application server?
Source: https://community.blueprism.com/communities/community-home/digestviewer/viewthread?GroupId=145&MID=2448&CommunityKey=3743dbaa-6766-4a4d-b7ed-9a98b6b1dd01
5 REPLIES 5
harish.m
Level 12
Hi Patrick Mueller,
 The scheduler tested in the above scenario,  how many tasks you have created. Did you put wait time after each task completion.
I would  make sure the wait time is updated appropriately based on the  windows login and log out time.
PatrickMueller
@Harish Mogulluri So actually it is even more strange - so the machine is totally idle - nothing scheduling, nothing planned.
When I try to run a schedule manually for this machine (or even a planned schedule) I receive this message - always - when I drag and drop a process to the machine and start it from the control room without the scheduler...it works perfectly fine.
It only happens on this one machine and I do not know why.
LeonardoSQueiroz
Level 10
PatrickMueller
@LeonardoSQueiroz Wow - that really solved the issues - we restarted the application server service overnight and now we are not receiving this time out issue with that one particular resource any more - thank you very much !
LeonardoSQueiroz
Level 10
Hello Patrick,
Glad it went right.
