Hi Mayank,
I think we are not sure why You are getting this issue, I have some suggestion but not sure it will help you or not.
1.Please check that you are using IE 11
2.Check Compatibility and retry.
3.Check same application with chrome ( if its working fine then issue is with IE)
4. If still issue is there then use Ctrl + and Ctrl - ( this is just temp solution)
Nilesh
Nilesh Jadhav
Senior RPA Specialist
Nilesh Jadhav.
Consultant
ADP,India
