Get Error while using login method of login agent
GuptaKancharla1
Hi , We are trying to establish login agent in our system.We are successfully able to log out through login agent and we could see control has been taken by login agent. But when we try to run login method,the process is terminated with the error "ERROR:  : 0: LogonUI callbacks not disabled".   Can anyone please guide how to fix this issue and make our login successful.   Thanks
First place to go (before starting a forum thread) is the knowledgebase: https://portal.blueprism.com/customer-support/knowledge-base/logonui-callbacks-not-disabled
