Hi Denis,
It seems the issue is related to the window not being currently active, but when I try to use Activate Application, I get the following error:
Internal : Failed to perform step 1 in Navigate Stage 'Activate Application' on page - Exception during remote setforegroundwindow - System.ComponentModel.Win32Exception (0x80004005): Access is denied
at System.Diagnostics.ProcessManager.OpenProcess(Int32 processId, Int32 access, Boolean throwIfExited)
at System.Diagnostics.Process.GetProcessHandle(Int32 access, Boolean throwIfExited)
at System.Diagnostics.Process.OpenProcessHandle(Int32 access)
at System.Diagnostics.Process.get_Handle()
at BluePrism.ApplicationManager.clsLocalTargetApp.ForceForeground(IntPtr hwnd)
Any advice would be helpful.
Rob
