Help! - Unable to Spy anything in Blueprism 7.3
kuhoog
Hi Team,
I'm unable to spy anything in any mode using my Blueprism 7.3 learning edition.
Facing the below error-
"There was an error during the spying operation.
System.InvalidOperationException: One or more errors occurred.
   at BluePrism.AMI.clsAMI.Spy(Boolean includeAiSurfaceAutomation, Boolean includeAutoSpyMode, Boolean includeAutomaticAttributeSelection, Boolean allowSpyMultiple)
   at AutomateUI.frmIntegrationAssistant.HandleSpyOrLaunchClick(Object sender, EventArgs e)"
Could you please help!
Let me know if you need any further information.
Thanks & Regards,
Kuhoo Gaur
LeonardoSQueiroz
Level 10
Check if this topic helps you, the error message seems to be similar:
https://community.blueprism.com/t5/Product-Forum/Problem-Spying-Elements-in-Java-mode/td-p/75501
