Hi, I have written code in Visual basic to connect to Azure Storage Blob and download it. It works on Visual Studio IDE but when I try to create an object based on the code I am still getting errors "could not load file or assembly. The full error message: Internal : Could not execute code stage because exception thrown by code stage: Could not load file or assembly 'System.Memory, Version=4.0.1.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51' or one of its dependencies. The system cannot find the file specified. External References: System.dll System.Data.dll System.Xml.dll System.Drawing.dll System.Core.dll Azure.Core.dll Azure.Storage.Blobs.dll netstandard.dll Azure.Storage.Common.dll System.Runtime.dll System.Memory.dll Namespace Imports: System System.Drawing System.Data Azure.Storage.Blobs Azure.Core Microsoft.VisualBasic Azure System.Runtime MyCode: 'Declare variables Dim SAS_Token As String Dim Blob_Url As String Dim destination_pat As String 'Variables SAS_Token = "s
26-04-22 12:42 PM
System.dll
System.Data.dll
System.Xml.dll
System.Drawing.dll
System.Core.dll
Azure.Core.dll
netstandard.dll
System.Runtime.dll
System.Memory.dll
Namespace Imports:
System
System.Drawing
System.Data
Azure.Storage.Blobs
Azure.Core
Azure
System.Runtime
MyCode:
'Declare variables
'Variables
SAS_Token = "sv=2020-07-04&st=2019-03-14714%3A12%3A54Z&se=2025-12-31T14%3A12%3A00Z&sr=c&sp=rdl&sig=YTryIR1idyBn3sK720o5ZBa9TjJ7rwrBW62pV0%3D"
Blob_Url = "https://servernew.blob.core.windows.net/bot-new/QA/83e65d5.zip"
destination_pat = "C:\Users\BOT222\Desktop\New folder\test.zip"
'Create serviceUri object
Dim serviceUri As New Uri(Blob_Url)
'Create sasCredential object
Dim sasCredential As New AzureSasCredential(SAS_Token)
'Create BlobClient object
Dim blobClient As New BlobClient(serviceUri, sasCredential)
blobClient.DownloadTo(destination_pat)
Do you have idea what should be done to make this code works or do you have ready object to work with?
Thank you in advance
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
System.dll
System.Data.dll
System.Xml.dll
System.Drawing.dll
System.Core.dll
Azure.Core.dll
netstandard.dll
System.Runtime.dll
System.Memory.dll
Namespace Imports:
System
System.Drawing
System.Data
Azure.Storage.Blobs
Azure.Core
Azure
System.Runtime
MyCode:
'Declare variables
'Variables
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
26-04-22 01:24 PM
@Mateusz Wojcik,
What version of Blue Prism are you running? Have you checked the Automate folder to see if there is a System.Memory.dll file in it?
