I need to access Hive dataware house to fetch some details.I am using OLEDB utility for setting the connection.The connection string format is " jdbc:hive2://:/;user=;password=; ". I am passing the same in OLEDB utility ConnectionString Variable. But I am getting below error. Kindly Suggest.
Error : " Internal: Could not excite code stage because exception thrown by code stage: An OLE DB Provider was not specified in the ConnectionString. An example would be, 'Provider = SQLOLEDB;' "
Thanks in advance,
Sahela J
I don't know about Hive but the connection string for Excel looks something like this:
Provider=Microsoft.ACE.OLEDB.12.0;Data Source=""C:\Temp\Testfile.xlsx"";Extended Properties=""Excel 12.0 Xml;HDR=NO;"";
I would expect your connection string to look something more like that (with Provider= etc...)
Hi Sahela, I need to access Hive server database house to fetch some details.I am using OLEDB utility for setting the connection. if you find any solution kindly Guide us.
