How to extract, save and send process logs automaticall?y
RonAng
Is there a way somewhere in the process or BO, that it extracts the BP process logs then save it to a text or csv file then send it via e-mail?
Hi Ron,
Log extraction can be done in a number of ways, and I am going to assume you don't want to use a implementation like Data Gateways and solely want to just take logs.
You can use AutomateC.exe to complete this (https://bpdocs.blueprism.com/bp-6-9/en-us/helpCommandLine.htm), from memory, using a combination of the /report to get the Session ID and /getlog you can export this functionality. If Session ID is causing troublesome, you can download the Splunk asset of the DX and use the custom object there to extract it. Its not the simplest, but it does the job.
Best regards,
James
James McLintock Design Authority
Process Analyst and Developer
