Hi
@Ronaldo_JuniorO,
You can open any action page within any business object in Object Studio. Upon double clicking on the 'Start' stage, you can see that you will get the start stage properties where you can add input parameters and map them to data items in that action page to map.
For example, below you can see I have opened the '
Start' stage of the '
Remove Blank Rows' action within '
MS Excel' VBO. Here, I can click on the 'Add' button and assign input parameters to different data items:
![27782.png 27782.png](/t5/image/serverpage/image-id/27917iF98EDF4158C026BE/image-size/large?v=v2&px=999)
WonderBotz India Pvt. Ltd.
Website:
Hope it helps you out and if my solution resolves your query, then please mark it as the best answer
