How to migrate BP process to other RPA tools.
sidram.m
Hi ,
Do you have provision to convert Blue prism process to other tools ex: Blue prism process to AA/Uipath.
Sidramappa Hunashyal
SA
Accenture
AnuraagPandey
Hello @sidram.m,
This one is quite tricky tbh.
I read an article sometime back from a firm "Blueprint", they are working /building tools for seamless migration​ from one vendor to another.
But that's all I can add to this thread 🙂
Have a good one!
Anuraag Pandey
msg Systems AG
Hannover, Germany
AndreyKudinov
Level 10
Just rewrite it using other tool.
Convertors like this are hardly usable between different programming languages and would be even harder between "low code" rpa solutions.
Ignoring the fact that converter would need to be able to read/write two proprietary/undocumented process descriptions, you'd also need some kind of mapping between objects on both sides. If you take into account that you might have custom VBOs with code stages, that would be almost impossible to create such a tool.
Andrey Kudinov
Project Manager
MobileTelesystems PJSC
Europe/Moscow
