How to update Secrets in Hashi Corp Vault
Soumya21
I am using HashiCorp Vault - Secrets Engine : KeyValue API In blueprism
When I work with the above api response is 200 and response content is 802032 characters
I am not getting exact response
Can anyone help on this
Soumya k RPA Developer
Qualesce India Private Limited
Bangalore
Hi Soumya,
Is the API returning some informative data in the response or just a series of random characters? Check that inside the body it is not returning an exception, in some cases it may be returning 200 as a false positive, but in fact there is a problem. One of the cases I saw this was in an API that returned 200, but within the body of the response I had the correct code (400) and the reason (authentication);
Regards.
Leonardo Soares
RPA Developer Tech Leader
Bridge Consulting
América/Brazil
