How to use Field Info in Text to Columns Code stage
SasikanthMachav
Hi Everyone,
My issue : Field Info(Array)
I need to convert text or custom column to date column using text to columns code stage.
I am unable to declare the array properly and use it because of which; it is throwing error.
Error : parameter incorrect(invalid_arg)
I am Using the below Code :
____________________________________________________________________________________
Dim wb, ws, sheet, excel, range As Object
Dim arr1 = New Object(0, 1) {{1, 4}}
Try
wb = GetWorkbook(Handle, Workbook)
ws = GetWorksheet(Handle, Workbook, Worksheet)
wb.Activate()
ws.Activate()
excel = ws.Application
sheet = excel.ActiveSheet
range = sheet.Range(Reference)
excel.DisplayAlerts=false
range.Select()
 range.TextToColumns(Destination:=Range(DestinationCell), DataType:=1, _
 TextQualifier:=1, ConsecutiveDelimiter:=False, Tab:=True, _
Semicolon:=False, Comma:=False, Space:=False, Other:=False, FieldInfo _
:=arr1, TrailingMinusNumbers:=True
Success = True
Catch e As Exception
       Success = False
       Message = e.Message
Finally
       wb = Nothing
       ws = Nothing
       excel = Nothing
 End Try
Can anyone please help me fix it!!!!
Sasikanth Machavarapu
6 REPLIES 6
ewilson
@SasikanthMachav,
So you have a single column of data, correct? If so, change your array declaration to something like this:
Dim arr1(,) As Integer = {{1, 4}}
michaeloneil
Hi
I think Eric is correct, I built a similar action but I made teh declaration Dim arr1 = New Integer (3, 1) {{1, 1}, {2, 1}, {3, 1}, {4, 1}}
Hope this helps
Michael ONeil
Technical Lead developer
NTTData
#MVP
Hi Eric,
I tried the way you suggested and declared the array, but seems its not working . Its throwing the same error :Parameter incorrect(INVALID_ARG)
Can you think of anything else?????
Hi Michael,
Didn't get your array declaration actually.
The array value that is needed is Array(1, 4), if you see the below macro recording of the manual
operation.
I am trying to put the below thing in BP editor , where the array declaration is going wrong or not sure what's going wrong, the code stage is throwing the
error : Parameter incorrect(INVALID_ARG)
Let me know if this is clear of my ask and could you help me on this
Hi
Sasikanth, below I've shared the code I used for my text to columns action. I built this a while ago and its been working fine on several developments so hopefully you find use of it. The set range sets the range if the endcell is not provided e.g. "A1" would then be set as "A1:A1"
Inputs - handle, wb name, ws name, startcell (this is the first row of the values you want to split A1), endcell (last row of values to be split A1000), split char (the character you want to delimit with such as | )
Outputs - Success, Message
Dim wb, ws As Object
Dim excel, sheet, range As Object
Dim matrix = New Integer (3, 1) {{1, 1}, {2, 1}, {3, 1}, {4, 1}}
Try
wb = GetWorkbook(handle, Source_Workbook)
ws = GetWorksheet(handle, Source_Workbook, Source_Worksheet)
wb.Activate()
ws.Activate()
range = sheet.Range(CellRange)
range.Select()
    excel.Selection.TextToColumns (Destination:=sheet.Range(Startcell), DataType:=1, _
        TextQualifier:=-4142, ConsecutiveDelimiter:=False, Tab:=False, _
        Semicolon:=False, Comma:=False, Space:=False, Other:=True, OtherChar _
        :=Split_Char, FieldInfo:=matrix, _
        TrailingMinusNumbers:=True)
Success = True
Success = False
Message = e.Message
Finally
wb = Nothing
ws = Nothing
End Try
Michael ONeil
NTTData
#MVP
@SasikanthMachav,
That last example implies you're running this directly within your​ Excel worksheet as a macro. Is that the case, or are you running this in a Code stage within Blue Prism? There are subtle differences.
As an example, if you're running this in a Code stage you need to enclose the parameters in parentheses.
Ex:
range.TextToColumns(Destination:=Range(DestinationCell),DataType:=1, TextQualifier:=1,ConsecutiveDelimiter:=False,Tab:=True,Semicolon:=False,Comma:=False,Space:=False,Other:=False, FieldInfo:=arr1,TrailingMinusNumbers:=True)
