How to use Shift+F10
AnkitShukla11
I am try to use shift+f10 but getting error please help
Ankit Shukla
@Ankit
There is a similar post here https://community.blueprism.com/discussion/menu-key-for-global-send-key-event that answers it.
Shashank Kumar
Singapore
+6581326707
21685.pngNot working
Ankit Shukla
Arvius Software Pvt Ltd.
Noida
Hi Ankit
You are not using the correct format, you need to use Global Send Keys and then <{SHIFT}{F10}>{SHIFT}.  You are using shift in quotes as a text item, it's a key on your keyboard with the name of "Shift".  If you are still stuck, check out the link Shashank provided above.
BTW there are 2 "shifts" above; the first presses the F10 key, the second one releases it - if you ever forget to release the shift key, you end up with some strange text appearing next time you write any text!!
Ian Meldrum
Senior RPA Developer
Royal Surrey NHS FT
UK
Ian Meldrum Senior RPA Developer Royal Surrey NHS FT UK
