I am not able to Launch and Spy oracle applications
26-07-18 03:43 PM
Hi All
i have tried to launch Oracle applications by Java Based, Windows based and browser based method.
could you please suggest which one is suitable for oracle to launch and spy also i have attached snap shot for your reference.
Suresh
27-07-18 01:06 PM
Is your application getting launched and attached using App Modeller?
if No, then firstly check if two instances of your application are getting launched or not??
If yes, then proceed for spying using attaching an instance of application using 'Attach' option.
Use Windows or Active Accessibility (AA) for spying the elements.
30-07-18 01:48 PM
Make sure you have Java Access Bridge enabled, then you should be able to attach to Oracle Forms as java application.
https://docs.oracle.com/javase/7/docs/technotes/guides/access/enable_an…
