Identify IE/Chrome/Edge Objects and Dependency Processes
ArjunGowdaKR
Currently we are working on Migration projects
  • Internet explorer to Microsoft Edge browser
  • Chrome MV2 to MV3
For this we need to identify the list of objects and processes that are using Internet explorer, chrome and edge. To find these processes manually is a tedious task.
So, we are checking is Blueprism have any tool to provide the list of objects and dependency processes in excel file?
Arjun Gowda
Software Developer
Shell India
UTC
BohyonHwang
Level 9
Refer to the following Blue Prism DX assets.
Process for Manifest v3 Impact Assessment Utility
https://digitalexchange.blueprism.com/dx/entry/3439/solution/manifest-v3-impact-assessment-utility
Provides a view of VBOs that are impacted by the new Manifest v3 standard for Chromium-based browsers.
Process for IE Mode Conversion Assistant
https://digitalexchange.blueprism.com/dx/entry/3439/solution/ie-mode-conversion-assistant
Essential utility for migrating IE objects to Microsoft Edge Internet Explorer Mode.
Function for Application Modeller Conversion Tool
https://digitalexchange.blueprism.com/dx/entry/3439/solution/application-modeller-conversion-tool
Enables quick bulk conversion of application modeller elements and attributes from one mode to another e.g. Internet Explorer to Chrome.
Process for Internet Explorer to Chrome Conversion Report
https://digitalexchange.blueprism.com/dx/entry/8797/solution/internet-explorer-to-chrome-conversion-report
A Blue Prism Process that will analyse the Internet Explorer Business Objects and produce a report.
Bohyon Hwang
Director
블루프리즘
Seoul
+82262033950
Hi Arjun,
I've used to below method to get the report of the process and object and their dependency, If you want application-wise (chrome, edge, IE) you can create your own query to get the report
If any efficient way plz let me know, Happy Learning :)
Prasanth
Software Engineer | RPA Developer
Thanks Prasanth Software Engineer | RPA Developer
