Identifying Enabled Input filed on a GUI
WikusKirsten
Hi All,
In the process of migrating an automation from Internet explorer to Microsoft edge.
We are interacting with a web based application, where we identify and extract information of erroneous row. The GUI provides a hyperlink, that when clicked takes you the specific row that is in error.(attachment 0)
Using IE previously, with the HTML spy mode, there was an "Enabled" attribute available. We used this attribute, to determine which row contains the error and the using the "Path" attribute dynamically, extracted the info we required.(attachment 1)
Working with Edge, I've played with some of the spying modes but cannot find a solution to mimic what was done previously. When using the 'Browser" mode, we are able to get the path of a specific Input cell.  However, I can't find a attribute that shows me if the cell I'm on is enabled or not.(attachment 2)
Using the UI spying, I'm able to identify if the cell is enabled, but cannot get the path to identify the row number with the error. (attachment 3)
Any suggestions would be welcomed.
Wikus Kirsten
Hi @WikusKirsten,
It seems like you already have opened up a similar thread​ under the same topic to which I also have posted a reply: Blue Prism Product - Blue Prism Community Site
Also, is it possible that we keep it limited to one thread under one topic since it will be easier for everyone to track the same as well?
P.S. This thread is also missing attachments which can't be seen due to some reason
WonderBotz India Pvt. Ltd.
Apologies, this is a duplicate of the first one. I didn't see the first one uploading. Will try to remove this
Wikus Kirsten
