Interact Plugin installation issue
AnindyaMukherje
While trying to install the plugins for Interact I am getting the below mentioned error message. has anyone faced similar issues?
what access privileges and on which account  the folder access needs to be provided
Not Installed plugins
  • Package Connect.SelfServe.Forms 4.2.0.106 could not be installed: Failed to read NuGet.Config due to unauthorized access. Path: 'C:\Windows\system32\config\systemprofile\AppData\Roaming\NuGet\NuGet.Config'.
Anindya Mukherjee
Consultant
EY
Hi, Anindya,
I haven't but it brings the obvious question - what permissions does the user have that is running the installation?
Zdenek
Zdeněk Kabátek
Head of Professional Services
NEOOPS
http://www.neoops.com/
The user is running as admin rights but still facing the same issue.  can we download the Nuget package offline and manually install it? Or the question is can we change the default location of the  NuGet. config file location through web.config file as it is can't access the path.
Physically both the  file and folder path doesn't exist
Anindya Mukherjee
Consultant
EY
Hi Anindya
Please contact [email protected] and someone will be able to assist with this issue.
Joe Farr
Product Consultant
Blue Prism Limited
