I suggest checking your data type.
Internal : Could not execute code stage because exception thrown by code stage: Method's type signature is not Interop compatible.
15-12-20 08:11 PM
Bhavana Paul
IBM
16-12-20 11:37 AM
Hossein Azimi
Customer Support Engineer, APAC
Sydney NSW
13-10-22 10:18 AM
Would you be able to share how did you convert the timespan to text format.
Divas
divas gupta
16-10-22 08:20 AM
Thank you for contacting customer support.
You can change the data type from timespan to text format from inside the data item properties.
Hossein Azimi
Sydney NSW
15-11-24 03:05 PM
hi, with this answer, I need a timespan to be in my data as Excel can't give me the correct answer when looking for the time difference between two times (across 2 dates).
If I simply change the TimeSpan to Text, then all my previous work wouldn't work as I need the timespan. How do I get the timespan to a text without just changing the drop down please so it can write to excel?
15-11-24 03:38 PM - edited 15-11-24 03:39 PM
If are just looking to use the Set Cell Value in Blue Prism's MS Excel VBO, you can simply put the TimeSpan data item into the Value parameter. When you drag the data item into the parameter Blue Prism will complain that that is not the correct data type but at run-time it will automatically cast the TimeSpan as text.
RBC
Toronto, Ontario
Canada
