Is RabbitMQ still required in Decipher v2.3?
uncki2
Dear Connections,
I would like to check if decipher v2.3 still require rabbitmq.
If yes, what is the road map for decipher to support newer version of RabbitMQ? We had RabbitMQ v3.11 installed when we did the installation of decipher v2.2. However as per below screenshot, RabbitMQ v3.11 support is getting ended on 31/07/2024.
Kishlay Singh Senior Consultant UOB Singapore
steven.boggs
RabbitMQ is necessary for Decipher 2.3 and is expected to be necessary for future versions as well. Noted in our Decipher documentation, RabbitMQ version 3.12.10 is compatible with Decipher IDP version 2.3, so you could upgrade RabbitMQ from version 3.11 to 3.12.10 to get around this upcoming end-of-support date.
With regard to your question about the roadmap plan for future versions of RabbitMQ, Decipher's compatibility with the most recent versions of Erlang and RabbitMQ are verified at time of release for each new version of Decipher.
