16-02-22 01:20 PM
Is the sample header case sensitive?
For e.g. I have "Invoice Number" and "invoice number" 2 different headers so just putting one of them will work or do i need to add both as sample header?
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
16-02-22 03:16 PM
Hi Tejaskumar,
The Sample Headers field is not case sensitive, so there's no need for repetition.
It's also capable of a fuzzy match, so "Grand Total" should also work for "Total".
Ben Lyons
Product Consultant - Decipher Specialist
UK
Ben Lyons
UK
Ben Lyons
SS&C Blue Prism
UK based
SS&C Blue Prism
UK based
6 REPLIES 6
16-02-22 03:13 PM
Hi Tejas!
You can do this with a Code Stage. In C# exists the function "Equals" for String Data types.
So... you can create a simple Code Stage with 2 inputs (str1 and str2 as a Text Data Item) and 1 output (blnEqual as a flag)
The code looks like that:
blnEqual = str1.Equals(str2);
Hope this helps you! And if this solves the problem, remember mark this as the best answer 🙂
Bye 🙂
Pablo Sarabia
Architect
Altamira Assets Management
Madrid
634726270
Bye 🙂
Pablo Sarabia
Architect
Madrid
634726270
16-02-22 03:16 PM
Hi Tejaskumar,
Ben Lyons
UK
Ben Lyons
UK
Ben Lyons
SS&C Blue Prism
UK based
SS&C Blue Prism
UK based
16-02-22 03:48 PM
Hi Pablo,
I think you may have missed this for Decipher IDP and code stages aren't part of this application.
Ben Lyons
UK
Ben Lyons
UK
Ben Lyons
SS&C Blue Prism
UK based
SS&C Blue Prism
UK based
17-02-22 06:38 AM
Thank you team for the quick update. This clarifies doubt.
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
15-12-22 10:21 AM
Also is it space sensitive or any other special characters?
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
Thanks & Regards,
Tejaskumar Darji
16-12-22 08:22 AM
Hi Tejaskumar,
Yes, I believe spaces are considered during the checks e.g. you would need Spacebar and Space bar, though clearly in this context they're very different things!
I believe most punctuation is ignored e.g. you don't need to add Invoice Number: and Invoice Number. Though I've had instances where different types of dashes have had an impact, so often it can be useful to copy and paste the exact type Decipher reads in Data Verification (this may still be different to what you can copy from the document).
Ben Lyons
UK based
Ben Lyons
UK based
Ben Lyons
SS&C Blue Prism
UK based
SS&C Blue Prism
UK based
