Is there any way to translate other language text to english text?
DhanavishnuramV
Currently I am doing a research in chinese website automation. I have successfully read chinese text with help of chinese language TESSARACT data. Do we have any way or utility which can translate other langauge text to english? Awaiting for the response & will be helpful for my research...
Barendde_Villie
You can make use of the ""Google Services"" VBOs. Take note that this requires an API key for the Google Cloud Computing services and there are pricing involved with this service. You'll also need an API key which you create on the Google Cloud Platform. Read through the ""Reference Architecture for Google Cloud Platform"" document supplied by Blue Prism as a starting point.    Regards. Barend
DhanavishnuramV
Thank you Barend, will go through your ideas...
Yeswa_Vaibhav_1
Hi Brendus, Is there any other way instead of API's to convert one language to another (example from chinese to english). As this is not a free of cost.  Regards, Vaibhav
