Hi Sanjay
I think you are on the right track. I'd suggest you to continue to work on wait stage and apply best practices to fix this problem.
The Process studio and control room may run faster than the Object studio.
So placing the wait stages are important to get it also run well in Process studio. You want to make sure the instance load/display before you attach/click etc.
Many may have thought having wait stage is unnecessarily and it has been complicating and slowing down the process. It is definitely not.
In Joe
In Joe Khor
Sr. Product Consultant
In Joe Khor
