JRE 9 is not working for spying java application
05-03-18 11:22 AM
I have installed BP 6.2 and JRE 9.0.4. (Both are 64bit version. )
after then I tried to attach java application.
but I got an error message from BP.
- same error occur after executing command "jabswitch -enable"
Could you give me an advice for this problem ?
Thanks.
Failed to launch application - Could not initialise Java Access Bridge support - Failed to load Java Access Bridge DLL. The file could not be found in any of the following expected locations -
Application Directory: c:\program files\blue prism limited\blue prism automate\WindowsAccessBridge-64.dll
System Directory: C:\Windows\SysWOW64\WindowsAccessBridge-64.dll
Windows Directory: C:\Windows\WindowsAccessBridge-64.dll
Current Directory: C:\Program Files\Blue Prism Limited\Blue Prism Automate\WindowsAccessBridge-64.dll
05-03-18 04:57 PM
There is a lot of help in the knowledgebase about getting JAB installed and working with your Java application. It is not always as simple as flicking a switch in windows settings, there are instances where your Java app requires a different version of JAB or a manual install of JAB into a non-standard location.
The main thing to remember is JAB is an Oracle Java technology outside of the Blue Prism product. I recommend installing and using Java Ferret and Java Monkey (provided by Oracle with JAB 2.0.2) to test your installation of JAB is working with your application - if not you need to investigate how to get JAB working with your app.
