I am working on Java Automation. In the application modeller for the Java applet the highlighting of elements is taking too much time when I use the Application Navigator. So I used only 3 attributes to identify which are role, Name and Match index which is taking around 60-70 seconds to highlight.
In the pdf which I found in the portal says to use Ancestor Count , Showing, Match Index and Match Reverse accordingly i.e role, Name, Ancestor Count and Match index which speeds up my highlighting by 5-6 seconds. Can anyone help me along to speed up the highlighting?
