Last-connection information lost after system reboot
HongJooChoi
Hi, Community.
My Runtime Resource is attempting to connect to a different server from the previous one after it's reboot.
I have manually revised the last-connection field of the config file shown below, but it was observed that the file is automatically over-ridden by Blue Prism when the system is reboot, resulting in the same error.
In my understanding, "C:\Users\beeno\AppData\Roaming\Blue Prism Limited\Automate V3\User.config "is the config file that defines the last-connection of the RR so that the RR can reuse the same connection when the system is reboot.
Did I miss something or have wrong understanding?
Best regards
HongJoo Choi
expertcr
You need to check the config file for the login agent; you pick the connection name to use after the machine restart or log off.
The config files are located here.
The connection name is added in the file, like in this example in the green box:
If you keep having issues, please get in touch with our technical support department.
Luis Lopez
Blue Prism Ltd
