Load Images into image data type using path
Babjee24
Level 7
I'm trying to read an image file into a image type data item. In order to store an Image it should be preselected in Image data item by My image path comes dynamically at the run time, in this case how do I read data in to image data item.
Babjee Vangipurapu
Senior RPA Developer
Wonderbotz
India
Babjee Vangipurapu
India
BohyonHwang
Level 9
I tried like this.
Bohyon Hwang
Director
블루프리즘
Seoul
+82262033950
Hi @Bohyon Hwang ,
Thanks for the reply. Can you please let me know the dll and namespaces to get the above code worked?
Babjee Vangipurapu
Wonderbotz
India
Babjee Vangipurapu
India
I set as follows.
Bohyon Hwang
Director
블루프리즘
Seoul
+82262033950
Hello Babjee,
Check one more alternative as below using the native function to read the image. This will work with any dynamic file path that you employ during automation.
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
