10-05-23 09:16 PM
Hi Community !
What`s up ?
We are sending the files in a single batch to Decipher but the processing is getting stuck in this status "Capture performed - ready for Verify"
Can you please help us with what can be done to solve this problem?
Regards.
10-05-23 10:42 PM
HI Guilherme Morandini,
Checck below thread
11-05-23 09:31 AM
Hi Guilherme,
Do you have Data Verify set to auto-skip on the config page? And do any of the documents have validation issues? e.g. Missing required fields, low confidence values.
Ben
11-05-23 12:44 PM
Hi @BenLyons
Yes. The Data Verify and Class Verify are set to auto=skip on the admin page.
The documents don`t have validation issues.
11-05-23 02:07 PM
Hi Guilherme,
I can't think of any other obvious cause for this, so it might be worth raising a support ticket.
(Note. Low confidence characters indicated by red text can also cause the batch to require manual verification)
Ben
