Login Agent - Unlock Screen doesn't work
PatriciaSwain
I was reviewing the BluePrism object that is supposed to unlock a VW AD session.  However, the unlock just executes the same page as the login code which includes LOGON and writing domain/username, which isn't necessary, so it's failing.  I think I need to update the code to use the existing Pipe Client (whatever that is) instead of creating a new one, and then change the WriteString command to only send the password.  Can someone provide the correct code or point me in the right direction?
Current "Authenticate To Windows" code:
Try
                'Create a new pipe client
                Using pipeClient As New NamedPipeClientStream(
                                "BluePrismCredentialProviderPipe",
                                PipeDirection.InOut,
                                PipeOptions.None,
                                TokenImpersonationLevel.Impersonation)
                                'Attempt to connect to it
                                pipeClient.Connect(10000)
                                'Send credentials
                                Dim dom As String
                                If Local Then
                                                dom = Environment.MachineName
                                Else If Domain = "" Then
                                                dom = Environment.UserDomainName
                                Else
                                                dom = Domain
                                End If
                                Dim ss As New StreamString(pipeClient)
                                ss.WriteString(String.Format("LOGON{0}{1}{0}{2}{0}{3}", vbLf, dom, Username, Password))
                                'Wait for reply
                                Using pr As New StreamReader(pipeClient, Encoding.Unicode)
                                                Response = pr.ReadLine()
                                                If Response = "OK" OrElse Response = "UNKNOWN" Then Return
                                                ErrorCode = pr.ReadLine()
                                                ErrorMessage = pr.ReadLine()
                                End Using
                End Using
Catch ex As Exception
                Response = "ERROR"
                ErrorCode = ""
                ErrorMessage = ex.Message
End Try
expertcr
The login agent process only has 4 actions: Change Password, Check Logged In, Login and Logout.
It is a requirement to disable the CTRL + ALT + DEL
Please review the following KB Article: How do I configure Login Agent Group Policy settings?
