Hi Nabin,
Assuming you are running your BOT in unattended mode. I would suggest, use "
Login Agent" and set up the policy of the VDI.
You will get all those documents in the BP document list how to set up the policy for Prod VDI and how to set up "login Agent" and how to schedule login agent in the scheduler.
Go through the document.
This will solve your issue for sure.
Thanks!
Debashis Ghosh
Debashis Ghosh
