Looking for help on writing a SQL query for OLEDB
27-02-22 05:02 AM
Currently i am using OLEDB database to open an excel with name "excel" and "2 columns" as , start date and end date , currently iam using the below SQL query to extract the values of the rows with todays date as below
"SELECT * FROM [Excel$] WHERE [Start date] Like '%" & [Today] & "%'"
please can some one help me to get the SQL query for extracting the rows with dates between the start date and end date
Thankyou,
Miya
Miya
Thankyou,
Miya
Miya
27-02-22 08:08 AM
Hi @Miya
In this case, you want to filter dates, so need to use any of this operators: >, <, =, >=, <= or <>
LIKE operator is used when you have text
So, you correct syntax looks like this:
SELECT * FROM [Excel$] WHERE [Start date] = DATE()
You can use the internal function of OLEDB SQL "DATE()" to get the current date. (Its the same as giving a Data Item value with Today())
Hope this helps you, and if this solves the problem, remember mark as best message
See you in the community, bye 🙂
Pablo Sarabia
Architect
Altamira Assets Management
Madrid
634726270
Pablo Sarabia
Architect
Madrid
634726270
02-03-22 03:33 AM
Hi Pableo.
Thank you, actually iam looking for query where i need to filter the values between 2 columns when the column values fall in todays date. For eg column1 date is 28 feb 2022, column 2 date is 3rd march this particular row should get selected.
Miya
Miya
Miya
Miya
02-03-22 08:49 AM
Hi M,
If I understand your requirements correctly, you have to check both columns for your date.
Something in style with:
SELECT * FROM [Excel$] WHERE ([Start date] <= DATE() AND [End date] >= DATE())
If I'm totally off here, then I do not understand what you are trying to select...
Happy coding!
Paul
Sweden
Happy coding!
Paul
Sweden
Happy coding!
Paul, Sweden
Paul, Sweden
