Loop issues
JoséAgostinho1
Hi, I´m now working in a process and I´m using a loop, when select the collection that I want to use, there is no probelm, but when I run the process the collection desapear, and I receive the message below:
"Invalid Collection supplied for For Each loop"
could you please help me
Thanks in advance
José Agostinho
_Amlansahoo
Level 11
Hi Jose,
May be that collection is not accessible to that particular page. In Blue prism you can see list of all the collection but you have to choose only which are accessible.
Hope it helps you.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
MadhurChopra
Hey Jose,
Can you please elaborate on what you mean by "select the collection"? Also, it will help if you can post a screenshot of the loop or upload the release file with just the loop you are facing issues with.
Madhur Chopra
Madhur Chopra
Sr. Product Consultant
Blue Prism - Professional Services
America/Los_Angeles
Hi all,
Fortunatelly the lopp issue was solved, but I had to performa a new process, and did the same step "select the collection and the operation was succeed.
Thanks all for you help
José Agostinho
