MAPIEx installation - question
22-08-17 05:44 PM
I just tried to install MAPIEx according to the guide and I am somehow confused.
In 2.1 you write:
"Note: The MAPIEx files must reside in the same directory as the Blue Prism program files (typically C:\Program Files\Blue Prism Limited\Blue Prism Automate). If they are installed to different directories, the MAPIEx functionality will not work when attempting to access an Exchange server from within a business process. As such, the DLL files in the MAPIEx installation directory should be copied to the Blue Prism installation directory before use on a particular resource. Once copied, any resources on that machine will have to be reloaded to pick up the new DLLs."
In 2.2.2.1 you write:
"If you install the 32-bit version of Blue Prism into a 64-bit installation of Windows, the installation directory"
I have 32bit BP and 64bit OS. When I run MAPIEx installer it suggests to be installed in Program Files (x86). However my BP is installed in Program Files (it was suggested by the setup). So should I use Program Files (where BP is installed) or Program Files (x86) as suggested by the MAPIEx installer?
At first I tried to install MAPIEx in the same folder as BP which is Program Files but the installer ignores the provided path and installs in Program Files (x86) anyway.
Shall I install the MAPIEx and the move all files from Program Files (x86) to Program Files?
Tomek A.
22-08-17 10:47 PM
BP 32bit should be installed in the x86 folder - I'd try reinstalling BP. Note also that the accompanying Mapiex VBO anticipates a 32bit OS but the configuration can easily be tweaked for 64bit OS (see Mapiex documentation). Note also that Mapiex only supports 32bit Outlook.
23-08-17 01:04 PM
Hi John,
Thank you for the reply.
I just double checked some things and my installer was x64. I wrote I had 32bit BP based on ""about"" where I saw CPU architecture which shows 32bit. This is why I was confused and decided to write the post.
Can you tell me how to check which BP version is installed (based on something else than installation path)?
Tomek A.
23-08-17 02:23 PM
Good question, I don't know to be honest. To be sure I'd uninstall and then reinstall - 32bit in Program Files (x86) or 64bit in Program Files.
23-08-17 02:44 PM
:D
I believe you could provide a feedback to your dev team about this. This kind of info should be in About window. As I mentioned, there is CPU Architecture field and it shows 32bit in my case but I have no idea what it is related to. My PC is 64bit, OS is 64bit and BP I expected as 64bit as well.
It is 5.0.30.0. Maybe you can check this in you environments as well.
