MTPuTTY Automation
faheemsd
Hi Team,
How to automate MTPuTTY  application with the help of Blue Prism?
Do we have any VBO's available In Blue Prism to work with MTPuTTY?
Need your suggestions on the above.
Faheem
SYED FAHEEM
DAR-ME
Cheers 烙易
8 REPLIES 8
steven.boggs
Hi Faheem,
There's not a VBO provided out-of-the-box in Blue Prism for "MTPuTTY", and a quick search of the DX doesn't yield any results.
Perhaps other Community members have automated MTPuTTY using Blue Prism in the past and could add their feedback in this thread, but I would also encourage you to submit this idea for a new Asset to the DX Ideas Portal here.
Steve Boggs
Austin, TX
Hi Steve,
Thank you for your response and I have submitted the Idea for a new Asset to the DX Ideas Portal .
Could you please share how other community members automated MTPuTTY usig Blue Prism? I will refer their suggestions.
Thank you.
SYED FAHEEM
DAR-ME
Cheers 烙易
Unfortunately, in looking for past instances of other customers mentioning "MTPuTTY" on the Community, this post is the only result. It would be up to other members to post their experiences, if any, in this thread.
While we don't explicitly state support for any specific applications such as "MTPuTTY" (with a few notable exceptions where we have had to build in specific support, i.e. the VBOs for the MS Office suite), the Blue Prism software provides methods for interacting with a variety of application types through a range of methods from in-depth interactions at a code level, to element identification, and to picture, color, and text identification methods.
So even though there isn't anything ready-made for "MTPuTTY" (like a VBO), you should be able to build business objects in the course of integrating with this application for the eventual automating of a process.
Steve Boggs
Austin, TX
Hi Steve,
Thank you for the response and I will try to create the Object for PUTTY  and use the existing spy modes.
SYED FAHEEM
DAR-ME
Cheers 烙易
BohyonHwang
Level 9
Why don't you try to use Connector for SSH.NET - 1.0.0 in DX.
SSH.NET should be able to do most of what putty does.
Bohyon Hwang
Director
블루프리즘
Seoul
+82262033950
@Bohyon Hwang
Thank you for your reply and May I know what is the Private Key FilePath parameter here? If possible could you please help me from where can I get it?
SYED FAHEEM
DAR-ME
Cheers 烙易
The ssh-keygen program can generate RSA keys for use by the SSH protocol in a directory called .ssh in your home folder.
That must be C:\User\<yours>\.ssh\authorized_keys.
Bohyon Hwang
Director
블루프리즘
Seoul
+82262033950
Hello @Bohyon Hwang
This is the folder path where I have placed the file from .ssh folder
I'm trying to run the  below and getting the error as Access to the Path has denied
Could you please help me here?
SYED FAHEEM
DAR-ME
Cheers 烙易
