Missing Navigate(root element) option Edge in BP6.10.2
Sasi_Kumar_Redd
Hi Team,
I am not getting the navigate option for the root element in BP6.10.2 Edge browser.
Would you please help me.
Sasi Kumar Reddy ValipiReddy
IT
Aviva
5 REPLIES 5
Hi Sasi Kumar,
Thank you for contacting Blue Prism Community.
Can you please provide a snapshot of the symptom?
Hossein Azimi
Customer Support Engineer, APAC
Sydney NSW
Hi Sasi,
Thanks for the snapshot.
Can you please share more details on what do expect to see/get in this navigation stage option?
Hossein Azimi
Sydney NSW
ritansh.jatwani
Level 9
Are you looking for an option to navigate to a new URL using the root node in Navigate stage?​
Consultant
EY
Gurgaon
EVIPUTI
There is no navigate option is root element . Navigate is a stage where you can use launch option to jump to the desired application .
Vipul Tiwari
Senior Process Simplification and Optimization Designer(Solutions Architect)
Fidelity International
If you're looking for the option "Navigate URL" that was in IE automation which was used to navigate to another URL, that wasn't at the root node even in IE. But anyway in Edge automation, it is called "Set Address", and you need to use a browser mode element for the option to show up in the dropdown for an action to perform.
Dave Morris
Cano Ai
Atlanta, GA
