11-10-17 10:50 AM
I have spied a text box in an windows based application (using accessibility mode)
When I try to perform Write to operation, it returns the below error :-
"Value does not fall in the expected range"
Hence I used alternative approach : Use focus, and send global keys to fill the text box with value.
But the problem here is, it gets appended to any existing values in text box. Is there anyway I could overcome this issue?
I basically need to overwrite my desired value on the text box.
11-10-17 11:28 AM
Hi bharratmohan,
In your alternative appro, you can do one thing, clear the text box before entering the values using GSK,
e.g ""{HOME}{DEL 10}""&[Data_Item]
this will delete 10 (char,no whatever) (you can adjust the value according to your need)
hope this helps 🙂
11-10-17 11:28 AM
Hi bharratmohan,
hope this helps 🙂
