Object Blueprism.Automate.clsCredentialsActions does not exist
IshaSingh
Hi Everyone, I am using Blueprism version 5.0.33. I am trying to run any process that has the Credentials Object used for getting credentials. Whenever I try to do so on my machine via control room, it gives me the error - 'Failed to create session on ATRL3013 - Failed to get effective run mode - Unable to calculate run mode - object Blueprism.Automate.clsCredentialsActions does not exist' - and then no session is created. I have tried to run these processes on other machines and a session is generated successfully.  I went through the knowledge base and found this solution, which basically pointed to error 'object Blueprism.Automate.clsCredentialsActions does not exist'. This seems to be an in-built object, something which cannot be imported as a VBO. What steps should I take to rectify this? Thanks, Isha
IshaSingh
Hi Everyone, Thanks for reading this. I simply restarted my machine and voila! It is working :) I hope this can come handy to someone else in need. Thanks, Isha
