Opening an Excel Document from Control room
GAVIN.RUDLING
Level 7
Hi I am getting the below error when running from the control room in production. However when stepping through in Studio we cannot reproduce the error. This error has progressed from the Active-x issue, of which seemed to have been caused due to Excel Active-x settings in excel itself after MS office upgrades. Not it does not happen in the Create Instance action Where the Active-x issue was being triggered. this is now in the Open Workbook action.
Error Message: Could not execute code stage because exception thrown by code stage: Exception has been thrown by the target of an invocation. Internal
If anyone has experienced this before, please share any resolution in this regard. Thank you
Gavin Rudling
Digital Consultant & Developer
Cog3nt
Africa/Johannesburg
0813906789
Hi Gavin there are a few articles on this on in our knowledge base:
https://portal.blueprism.com/customer-support/support-center#/path/
http://portal.blueprism.com/customer-support/support-center#/path/1158824822
John Carter
Professional Services
Thank you very much John, much appreciated.
I will certainly go through the suggestions and hopefully resolve our issue.
Thanks again
Gavin Rudling
Gavin Rudling
Digital Consultant
081 390 6789
[email protected]
cog3nt.com
Stellenbosch
