Oracle Database Connection
Hello, I have to connect to a Oracle Database. After many issues, finally I could set the connection to Database, but now I have to open a session  or something like using BEGIN k.session#.open_session; END; before running SQL. I do not have a clue how to do that. Can anyone help on that please? Thank you very much
UmadeviNataraja
how did you connect to Oracle Database?
Umadevi Natarajan
Technical Analyst
Infosys
Plano TX
ewilson
@Enrique Lozano Granados,
Have you looked at the Oracle MDA connector?
https://digitalexchange.blueprism.com/dx/entry/3439/solution/oracle-mda---utility
